Dear Bill,
I'm not sure if this helps but, Volts x Amps=Watts. Therefore, since you are using a transformer and voltage is fixed, the only variable in the equation is the amp draw of the bulbs. Your old bulbs drew about .166 amps. Your new ones draw .0083. You could have 100 led's.
The Transformer is is just 2 coils, that transmit elec. magnetically as opposed to mechanically. There is no conductive connection between the circuits, which may be at arbitrary constant potentials. Only changes in one circuit affect the other. When a transformer is on, but no power is drawn, the draw is equal to the resistance of the coil. This is dissipated in the form of heat. There is some loss to the system due to the resistance of the coil material and the ferromagnetic material.
Long story short, your transformer will draw current at rest, but not 100 watts. Otherwise it will pull whatever amperage it needs up to its rated capacity (where there's usually a fuse).
BTW I'm not an electrical engineer so ne1 feel free to correct.
-tim
o/______\o
(Oo=00=oO)
