Originally Posted by Adam
http://www.mrbreakfast.com/feature_dd_coffeestains.asp
Coffee stains.......anybody recommend some tips.....i've used almost
everything.
mikey535im...........1991 535im , Schwarz , H&R/Boge gas ,17" Style 10's , EAT Chipped :eek: Colorful Colorado
I bought a gallon of this stuff for $17, and it takes out anything:
http://www.bluegoldcleaners.com
You can use it on anything that is safe to wipe down with water. I was covered in grease from head to toe after spending 3 days under the car doing the transmission swap and put a few ounces in with the laundry soap to wash my Levis and it took every spec of grease out of them as if I had never worn them.
There is nothing worse than a brilliant image of a fuzzy concept. -
.............Ansel Adams
I would hold off on hairspray and lighterfluid until you exhaust the water based stuff... try windex first....
Gordon Lawson
Niagara on the Lake
Ont., Canada
1989 535i 5speed "Eat'n"
Starter Fluid, Starter Fluid, Starter Fluid....
Ancient Chinese secret! Don't be afraid, it works! Apply liberally and let sit for a little bit (15 seconds) and wipe clean with absorbant cloth...repeat as needed.
Absolutely NO lighters or matches....
I had my carpet cleaned recently and talked to the guys about what they use. Form what they told me there are a couple of critical elements. Heat and an evaporating cleaning agent. This place used an alchohal based cleaning solution. You need to be careful that wharever you put into the carpet you can get out, otherwise it will attract dirt and continue to show the stain. My dad's neighboor has a carpet cleaning service. He did my car one with his hand wand. You might want to contact a carpet cleaning service and have them treat the stain and clean your carpet.
Derek A.
90 535i 5 Speed - Style 5 17"
You had to see "My big fat Greek wedding" to understand that.
Brian C.
cleaner that is great on spots. Spray it on, and blot the stain until gone. 3 dogs, 6 cats, 3 horses... we use it a lot (unfortunately!)
Always test the surface for colorfastness first.
