1. When the engine is running on low revs in neutral, I can hear pulsing sound and feel vibration in the car, but when I push the clutch, the pulsing stops. I think it started after I had the problem with my alternator, which was later rebuild.
possibly the twin mass flywheel is worn and rattling
2. When I sift the gears in low revs, I can hear banging from the rear (maybe differential) and vibration like something is loose.
id be looking at tranny mounts or flex coupler first, then possible bad driveshaft
3. I have problem with my trunk lock (button). Before when I press it, it was hard getting it back, but now it is very hard to press it and get it back, I have to use screwdriver to pull it back.
lube the hell outta it
