Thread: Strange headlight problem
    Mar 2004
    Lawrence, KS
    Default Strange headlight problem
    So i hit a large pothole coming home from work a few days ago and my right low beam goes out. I figured the hit had just broken the filament in the bulb(it's happened before), but the filament was intact and to test the bulb i put it in my left low beam and it worked fine. Next i went to the fuse box under the hood and while the fuse was fine it was not getting any incoming current. So i have traced the problem as far back as the headlight control module on the fuse panel on the drivers side under the hood. I couldnt figure out how to remove the headlight control module and was afraid of breaking it trying to get it out. Both highbeams, foglights and the left lowbeam work fine, and somehow the car is still able to recognize when there is not a bulb in the socket(it gives me the "Low Beam" warning on the display).
    Any ideas where to go from here would be greatly appreciated.
    Wellington,New Zealand
    aaahhhh sounds like you are on the right track lkm fix here
    Gone but not forgotten
    Default LKM removal, just pull up, nothing will break.
    Javier
    Mar 2004
    Lawrence, KS
    Thanks guys, sounds like this could be it. I will try this fix when i get some time this weekend.
    solder is your friend.
    Mar 2004
    Lawrence, KS
    It did turn out to be a broken solder on the LKM. I opened it up and one solder looked a little pitted, didnt really look too bad but i thought i would resolder it anyway and that was it.
    Thanks for the help.
  1. this is a strange problem
    Last Post: 01-27-2007, 12:58 PM
  2. Strange AT problem
    By ArtemLepilov in forum 5 Series BMW
    Last Post: 04-05-2006, 01:50 AM
  3. e34 Starting Problem ( Strange one )
    By Strap in forum 5 Series BMW
    Last Post: 09-15-2005, 08:03 AM
  4. strange problem..
    By peks in forum 5 Series BMW
    Last Post: 04-15-2005, 12:03 AM
  5. Help! Very strange problem! Anyone seen this one?
    By Jeff N. in forum 5 Series BMW
    Last Post: 10-10-2004, 06:36 PM
