i got my tis working sunday, ill go check.
Printable View
Javier
240290000 is listed as the oil pump article....
the problem with the number that you are giving me is that that is the number on top of the bulletin, not the one that can be searched for in the tis...ie, you gave me a 10 digit number....these are listed as 9 digit numbers for search. a tis expert like bill r could probably find them, however i can't. i looked manually for the emissions testing one, since that seems like it would reinforce the point to your mechanic, i can't find it. i'll post the thing about the oil pump, but i don't think it has to do with a regular a clutch/rev in neutral problem.
this bug was fixed from some production year, my car is early 92, may be it is out of the problem range.
In this case, I wouldn't mind.
The emission test TIS has this content:
June 1991
Service Bulletin 24 01 91 (3196)
Subject: Transmisison Failure during Exhaust Emission Testing
Models: All 1984, 1985, 1986 with 4-speed automatic transmission, 1987
635CSi, 735i, and L7.
Situation: There have been reported isolated cases of automatic
transmissions failing during a High Idle Exhaust Emissions Check. The
failures have resulted from a preconditioning procedure where the engine is
held at high rpm for a prolonged period of time. The following applies to
all states which have a High Idle Exhaust Emission Check.
As the internal transmission components experience normal wear over time,
the possibility of transmission damage exists if the vehicle is operated
for
extended periods of time at high rpm in PARK or Neutral. Such operation
does not constitute normal operating conditions. If, in exceptional cases
such as A/C recharging, injector cleaning, charging system tests, or
emissions testing, vehicle operation at high rpm in PARK or Neutral is
required the following setup procedure must be performed prior to beginning
such operations.
Solution: The emissions test must be conducted with the engine at
operating
temperature. If the engine is not at operating temperature prior to
beginning the test, it is recommended that the vehicle be driven for a
short
period of time to bring the engine to operating temperature. DO NOT run
the
vehicle at high idle to achieve operating temperature.
Once the engine has reached operating temperature, the following pretest
procedure must be performed BEFORE testing begins.
Setup Procedure for I/M Emission Test
1. Shift to PARK.
2. Turn engine OFF.
3. Wait at least 30 seconds.
4. Restart engine, LEAVE TRANSMISSION IN PARK.
After the engine is started, DO NOT move the gear shift selector through
the
Forward or Reverse gears before or during the test sequence. DO NOT EXCEED
2000 RPM.
5. Begin emissions test procedure.
6. If the vehicle fails the emission test, some states allow for an
extended pre-conditioning before the repeat test. In this case the
following procedure should be adhered to.
Precondition Procedure
1. Shift into PARK and turn the engine OFF for 30 seconds.
2. Restart engine, LEAVE TRANSMISSION IN PARK.
3. Engine may be preconditioned at a maximum of 2000 RPM for up to 90
seconds, at which time the repeat test must begin.
If the above steps are not followed, serious transmission damage can
result.
Note: Due to the unusual nature of the emissions check, this type of
failure does not take place under normal operating conditions.
You can see there that BMW did not consider a solution for this, and also located the fault for models from 1984 to 1987!!! There wasn't even E34's at that time!!
From Winfred post on the two repairs, it is clear that the correction is based in two Teflon seals, replacing steel seals. If there is something about this in the Oil pump TIS, then it is worthy, otherwise, as you think, may not be related.
Javier
as has probably been said before, the 4hp22 and hp22eh had this problem, and all the m20 and m30 e34s were equipped with this,.....methinks that bmw's solution if a car came in with this problem was to completely overhaul the tranny and that's why there might not be a partial rebuild datasheet to solve the problem.
correcting seals. I will burn a CD with all the info gather on this post and take it to the shop with the car. As the shop will have to disassemble up to D break, think it is time to replace the ofending seals to the A clutch.
Javier
