axle stands?
I wanna get under the front of my car, but if I jack the car up using the front jacking points, where can I put the axle stands?
Printable View
axle stands?
I use a hydraulic lift first to lift it up and then the jacks under the jackstand points.
You should get one, that is always needed for work. No need to buy an expensive one. I bought one for 20 $ which can lift 2 tons max.
I have several now and that really helps.
To be considered as basic tool for the DIYer.
forget the stock jack that came with the car and buy a floor jack. this is the best way and you will need it for other work.
Well I have a trolley jack, with 3 tonne capability, but I still use the original jacking points... Where else can I jack the front of the car from?
the front crossmember iz the one
http://www.realoem.com/bmw/showparts...99&hg=31&fg=05
Part number 1 in the diagram.
maybe put some wood (a thin piece) or some rubber between the crossmember and the jack so you don't mark / indent the metal when your jacking it. it's either this or the side jobbie you are talking about.
like here, it's been discuseed many times before.
http://www.bimmer.info/forum/showthr...nt+crossmember
That's just what I was looking for! Cheers Kriss!!
Shogun,Quote:
Originally Posted by shogun
Can you repost that picture you have of the jack points? You know the one I'm talking about. :D
-ashley
You can also get a set of ramps for other type of work.Quote:
Originally Posted by BM-BOY
This the one yur on about? Love this pic! http://www.bimmer.info/forum/showthr...ht=jack+points
http://www.r3vlimited.com/Tech/Jackpoints.jpg
Quote:
Originally Posted by acyre
I didn't see that picture when it was originally posted. That's great!!!!Quote:
Originally Posted by GaryE
