OEM basket weave rim 97 528i E39 to a 92 525I E34
I have a 92 525I E34 and recently put a basket weave rim from a 97 528i E39 with a 225 60-15 tires. It look good but the problem between 45 to 55 MPH the front car starts to wiggle and shake but it is perfect at around 60 MPH and beyond. Tried checking the wheel balance and rebalance again but same result rotated rims and balance same result.
I need answers and solutions if they are slight difference in offset sizes is there a way I can still use this rims on a E34. Is the hubcentric converter rings(7.25 mm diameter) the solution if it is anyone know where to buy them here in LA/CA or a site that I can go I would appreciate it very much.
Thank You All!
Kidlat
