3 Attachment(s)
Looking for Answers Definitive ATF fluids post
I would like to get some answers on the Lifetime atf fluids and in light of Mr. Graybeard and Tiger both saying they have used the Pennzoil product with no ill effects , thought i would start a thread trying to dig up as much info as possible
First off the only claims for pennzoil multi vehicle atf that i found that said it was ok for replacing various lifetime fluids was from a pennzoil dist. Johnryoung.com. Their data sheet indicated that it was ok but the pennzoil home website doesn't. They don't have a tech. hotline number to call for info only an email address and i didn't want a secretary to randomly answer my trans fluid query.
Then i searched for every body who makes any claims at all for replacements for any of the 4 special atf's that BMW or ZF specifies. Amsoil states clearly on their website that their synthetic atf is a suitable replacement for ESSO LT 71141 and the BMW 7045E but they don't mention the Shell La 2634.
Kendall versa trans is also supposed to be suitable for a replacement for all 4 of the bmw fluids. On a kendall dist. website i found this document but the same info was not on the Kendall website itself. There was a tech info hotline however and i called it this morning. The fellow that i talked to stated that yes it was a suitable replacement for these bmw fluids. But he also stated that if it was still under warranty he would stick with the manufacturers specs to avoid any potential argument from the manufacturer that you used a fluid that wasn't approved by them. He also said that if it was off warranty he wouldn't hesistate to use it and that they had tested the fluid in all the applications that specified special fluids with no problems. Here's various documents that i've found so far, since i'm limited to 4 per post i'll put them in additional posts. Any body else who has found any other sites or different fluids that also are compatible please post on this thread. Thanks.
3 Attachment(s)
Here are some more of the pages
that i've found
1 Attachment(s)
And here are a few more of related pages
as well
that i've found
3 Attachment(s)
Some more things i've dug up showing
Quaker state which is the same product as pennzoil multivehicle atf and also some stuff from valvoline
