Just a thought... When's my transmission going to die?
I had the fluid flushed at 180,000km (bought it at 165k), and the mechanic said it was well due for a change. I'm up to 196,000km on the original trans now, and obviously auto trans's don't last forever. I follow the service indicator and plan on getting the trans flushed every oil service, ie about every 20,000km.
I've seen/heard of many that have lasted over
200,000 miles. My 1991 525i, with the GM auto tranny, has 160,000 miles and is still working great with no repairs other than fluid/filters.
Ryan, what is your tranny filter replacement schedule?
Quote:
Originally Posted by ryan roopnarine
i'm driving my car for work right now, so i try to change tranny fluid at least once every 2 months (6k miles, 10k km). i only do a drainplug change. the reason i do this instead of the complete flush is that i've found that using it for work is REAAALLLL hard on it. yes, the fluid is still exceptionally pink, and passes the paper towel test, but i can tell from the smell that the chemistry has changed. by doing it partially every 2 months, i renew the additive pack somewhat, instead of letting it break down significantly more before replacing it all, this way, yeah, it is being "completely" changed, but its at my convenience, and it costs a lot less than taking it somewhere to be hooked up to the machine. i only use the syn. atf in the PS fluid, i don't bother anymore with using it in the tranny because its being replaced so often. its also a lot cheaper to do it with regular stuff, IE, i can buy 4 bottles of regular ATF for the price of 1 bottle of mobil1. i can just buy a case at 12.00 and have enough for 4 changes.
You still delivering pizzas with that thing???....
Or was it pick-ups for the Alachua County Sperm Bank? :p
Come-on....fess-up! What is your chosen lot in life?....at least for now! ;)
Brian C.
