BMW approved transmission fluids
Operating Fluids March 2008
Group 24 Automatic Transmission Technical Service
1.0 General Information On Automatic Transmission Fluids
2.0 Oil Additives
3.0 Approved Automatic Transmission Fluids For Initial Fillings
And Correcting Fluid Levels
4.0 Checking Transmission Fluid Level
5.0 Transmission Fluid Change Intervals (If Applicable)
Automatic Transmission Fluid was developed especially for automatic transmissions. It requires additives which arecarefully matched with each other, a high viscosity index and a solidification point below -40°F/-40°C.
Friction behavior of Automatic Transmission Fluid in plate-type clutches under very different operating conditions is extremely important. Other important factors are:
Wear protection
Oil film shear resistance
Adhesive property
Oxidation resistance
Corrosion inhibition
Sludge prevention
Temperature-dependent viscosity changes
Compatibility with sealing materials.
2.0 Oil Additives
Automatic transmissions are designed so that oil additives are not necessary. BMW disapproves the use of any oiladditives and cannot accept the liability for any consequential damage which results from using oil additives.
and Correcting Fluid Levels
3.1 GM Transmissions
USE OF ANY OTHER OIL WILL CAUSE A NON WARRANTABLE TRANSMISSION FAILURE
*Transmission identification plate can be utilized to determine proper transmission fitted in vehicle
A4S 270R (THM-R1W)
E36
318i/is/iC/ti from 1996 to 1999 production
323i/is/iC from 1998 to 1999 production
328i/is/iC from 1996 to 1998 production
Z3 1.9 from 1996 to 1999 production
Z3 2.3/2.8 from 1997 to 2000 production
All reputable brand name Automatic Transmission Fluids of the DexronŽ III formulation.
E39
528i/iT from1997-1999 production
A4S 310R (THM-R1)
E34
525i from 1990 to 1995 production
E36
318i/is/iC/ti from 1992 to 1995 production
325i/is/iC from 1992 to 1995 production
A5S 360R (GM5)
E46
323i/Ci/Cic from 6/98 to 3/00 production
323iT from 1//00 to 3/01 to production
328i/Ci/Cic from 6/98 to 3/01 production
The transmission oil pan will be labeled with either Texaco ETL 7045 or DexronŽ III, please fill or top off with the proper
fluid only. Do not mix Texaco ETL 7045 and DexronŽ III fluids.
See S.I. Bulletin B 24 01 98.
A5S 390R (GM 5)
E46
330xi from 6/00 production to present
325xiT from 9/00 production to present
E53
X5 3.0 from 8/03 production to present
E83
X3 2.5, 3.0 from 8/03 production to present
E85
Z4 3.0 from 9/02 production to present
Z4 2.5 from 9/02 production to present
No subsequent transmission fluid changes are necessary. Never mix any other oil with this transmission fluid when doing repairs or topping up.
ESSO LT 71141, BMW Part No. 83 22 9 407 807.
GA6L45R (GM6)
DEXRON-VI Automatic Transmission Fluid
E82
128i from 12/07 production to present
E83
X3 LCI from 9/06 production to present
E88
E90
328Xi from 9/06 production to present
E91
The fluid can be sourced locally until a BMW PN is available. If the fluid cannot be sourced locally contact your Regional Technical Specialist via PuMA
3.2 ZF Transmissions
ZF 3HP22, 4HP22, 4HP24
Utilizes Castrol TQ or Texaco Havoline Automatic Transmission Fluids of the DexronŽ III formulation. Never mix any other
A5S 310Z (5HP18)
E36
M3 from 1995 to 1999 production
Utilizes a lifetime filling of synthetic transmission fluid, ESSO LT 71141, no subsequent transmission fluid changes are necessary. Never mix any other oil with this transmission fluid when doing repairs or topping up.
E34
530i/iT from 1993 through 1995 production
Utilizes Castrol TQ or Texaco Havoline Automatic Transmission Fluids of the DexronŽ III formulation. Never mix any other oil with this transmission fluid when doing repairs or topping up.
A5S325Z (5HP19)
E46
323i/Ci/Cic from 3/00 to 8/00 production
325iT from 4/01production to present
330i/Ci/Cic from 6/00 production to present
325i/Ci/Cic from 9/00 production to present
E39
525i/iT from 3/01 production to present
530i from 3/01 production to present
A5S 440Z (5HP24)
E31
840Ci from 9/96 to the present
E38
740i/iL from 1/97 production to present
E39
540i/iT from 1/97 production to present
ESSO LT 711 41, BMW Part No. 83 22 9 407 807.
E53
X5 4.4i from 9/99 production to present
X5 4.6i from 9/01 production to present
A5S 560Z (5HP30)
E31
840Ci equipped with M60 engine
Utilizes a lifetime fill of transmission fluid, no subsequent oil changes are necessary on this transmission. If transmission
fluid is required for repair purposes, use only the oil approved for this transmission. It is not permitted to mix this oil with other grades of transmission fluid.
Shell LA 2634, BMW Part No. 83 22 9 407 765.
E31
840Ci equipped with M62 engine
850Ci equipped with M73 Engine
Utilizes lifetime fill of transmission fluid, no subsequent transmission fluid changes are necessary.
E32
740i/iL from 1993 through 1994 production
Utilizes a lifetime fill of transmission fluid, no subsequent oil changes are necessary on this transmission. If transmission fluid is required for repair purposes, use only the oil approved for this transmission. It is not permitted to mix this oil with other grades of transmission fluid.
E34
540i/iT from 1993 through 1995 production
Effective with model year 1995 and later:
E31
850Ci from 10/94 to 6/97 production
840Ci from 12/95 to 8/96 production
E38
750iL from 1/95 production to present
740i/iL from 7/94 to 12/96 production
E39
540i/iT from 3/96 to 12/96 production
GA6HP19Z
E82/E88
135i All
The transmission fluid has a Condition Based Service interval of approximately 100,000 miles; please refer to S.I. B00 07
02 for further information. Never mix any other oil with this transmission fluid when doing repairs or topping up.
Shell M-1375.4, BMW Part No. 83 22 0 142 516.
E90/91/92
325i, 328i, 330i, 335i, All
E60/61
525i, 530i from 8/03 production to present
GA6HP19ZTU
E70
3.0i from start production to present
E71
X6 xDrive35i
GA6HP26Z
E60
545i from 8/03 production to present
550i All
E63, E64
645Ci, 645CiC from start of production to present
650Ci, 650CiC All
E65
745i from 11/2001 production to present
750i All
E66
745Li from 3/2002 production to present
750Li All
760Li from 9/2002 production to present
The transmission fluid has a Condition Based Service interval of approximately 100,000 miles; please refer to S.I. Bulletin
B 00 07 02 for further information. Never mix any other oil with this transmission fluid when doing repairs or topping up.
GA6HP26ZTU
E70
X5 4.8i from start production to present
Due to the substantial expansion of transmission fluid when heated it is only possible to measure the oil level correctly at
specified oil temperatures (after driving a distance of about 12 mi./20 km). All transmissions should be checked between a
ZF 3HP and 4HP
See S.I. Bulletins B 24 02 85 (1027) and B 24 01 98.
A5S 560Z, A5S440Z, GA6HP19Z, GA6HP26Z, GA6HP26Z, A5S325Z, A5S 310Z
All 5 and 6 speed transmissions require the fluid to be checked when fluid temperature is between 30-50° Celsius using
DIS Plus or GT1. Do not check fluid level after temperature has exceeded 50° Celsius.
A4S 270R, A4S 310R and A5S 360R
For vehicles with or without a dipstick see S.I. Bulletin B 24 01 98.
Please refer to applicable Service and Maintenance Checklist for each vehicle.
March 2008
http://admin.webmakerx.net/images/Si.../autotrans.pdf
What is presently approved by ZF
Quote:
Originally Posted by
whiskychaser
If you own have a 5HP30 with the black label you will find it isnt supported any more as ZF have removed LA2634 from the 2013 approved list. A year ago they said you cant use their Lifeguard5 instead. Now they are saying it is 'best available'. This is subject of a discussion on a UK site. Anyone have better information?
Interesting. I don't think the oil companies can list applications reliably, but ZF does. Do you have any link/s?
Looking at ZF's latest approved fluids (PDF), we can see this does not affect other 5HPxx, 3HPxx and 4HPxx transmissions*, which should all use:
For Lubricant class 11B
ZF Friedrichshafen AG: List of lubricants TE-ML 11, edition 08.07.2013
Manufacturer, Trade name
AMALIE PETROQUIMICA, MADRID/ES, ATF DEXRON III
ARAL AG, BOCHUM/DE, ARAL GETRIEBEÖL ATF LD
BP PLC., LONDON/GB, BP AUTRAN LTF
CASTROL LTD, LONDON/GB, CASTROL TRANSMAX Z
DEUTSCHE PENTOSIN WERKE GMBH, WEDEL/DE, PENTOSIN ATF 1
ENI S.P.A., ROME/IT, AGIP DEXRON III
EXXONMOBIL CORPORATION, FAIRFAX, VA/US, MOBIL ATF D 21065
EXXONMOBIL CORPORATION, FAIRFAX, VA/US, MOBIL ATF LT 71141
KUWAIT PETROLEUM INTERNATIONAL LUBRICANT, ANTWERP/NL, Q8 AUTO 15
ZF FRIEDRICHSHAFEN AG, FRIEDRICHSHAFEN/DE, ZF-LIFEGUARDFLUID 5
* Except these:
4HP20, must use class 11A fluids
5HP18 with the green plate which must use ZF-LIFEGUARDFLUID 5 or PENTOSIN ATF or the BMW fluid ESSO LT 71141, BMW Part No. 83 22 9 407 807.
Strange. 5HP18 with the black place can use class 11B but not the green plate version? I guess they found some seals used in the green-plate trannies failing! (?)
Castrol's sites just quote:
"Check transmission colour coded label for specific transmission lubricant recommendation. THMR1 transmission with Black or green sticker, use CASTROL TQ DEXRON III; 5HP-18 transmission with Black sticker, use CASTROL TQ DEXRON III; 5HP-18/24/30 with Green sticker, use CASTROL TRANSMAX Z; 5HP-30 with Black sticker, use Shell LA2634; GM4/5 transmissions with Green sticker, use ETL7045
BTW, I read somewhere that Pentosin, and Castrol Transmax Z were tested and approved by ZF to be extended drain fluids. They are also approved by Voith, and are standard issue on buses and trucks that generate tons of torque. Here in Oz I have always used this green fluid in 4HP22s and my Black labelled ZF 5HP18 as ZF had recommended it for them. It gives great results and is only about 30% more than dino fluids.
Castrol Transmax Z
Full synthetic DexronŽ III type automatic transmission fluid with proven outstanding performance in high temperature and severe duty applications. Particularly suitable for competition use, towing or arduous use where high II or DexronŽ III are recommended. (TDS 1) (TDS 2)
