30# injectors.... not quite what I expected (Mark D please advise)
Ok so BJL4776 said he has 30# injectors on his M50 and it idled fine. I installed mine tonight and it was surging horribly. I unplugged the battery to let it reset the ECU and then I started it back up, it was a flatter idle. I took it up the street at <2,000 rpm drove it around for a few mins and then the idle was healthier if not perfect. However, if I went over like 3/4 throttle it would misfire and sputter. I think (obviously) it's because too much fuel is entering the combustion chamber. Now, since this is going to be for a supercharged application, I can alleviate that once my mechanic at Bimmers Only calls and says my damned pulley is done and I can install my s/c. Anyway, this was just to test the injectors since no one local wanted to flow-test them cheaply for me. So, yeah all 6 injectors work and work correctly... but unfortunately it looks like they either may not work out for me, or I will need custom software. I am hoping I do not need the software, and simply adding the additional air from the supercharger will help bring things back into range. I didn't even get to install the rising rate fuel pressure regulator, as it is 30# was too much fuel for NA, so no sense in that. So what do you think? Mark, if you're reading this, is there anything you can offer me? So far I've looked into piggyback ecu's b ut that only alters timing, not injector flow. Apexi S-AFC does the same by messing with O2 signal. Standalone is not an option, as I do not have $3,000 for an ecu. What should I do? I am going to run 6.5 psi. Should I just use stock 17# injectors and use the rising rate fuel pressure regulator to force more fuel out of the injectors? Or should I try the 30# again once I have the blower on? HELP.
You could get a split second psc-00# signal calibrator.
It could then be dyno tuned to smooth out the running, to compensate for the change in needed injector pulsewidth. The psc-001 has a built-in map sensor for additional input tuning ability. It also included additional sensor inputs for mapping purposes. http://www.splitsec.com/
Kinetic motorsport has the psc-001 on sale here,
http://www.kineticmotorsport.com/cat...nsor-p-62.html
http://www.kineticmotorsport.com/cat...cache/PSC1.jpg
I haven't yet installed & tuned my new psc-001. Walt, bought the psc-004, a strictly afm to maf version with a pre-installed map, & had it running decently immediately. His car was pranged en route to the dyno tuning session. :( I've been too distracted to address installing mine in the last week.
Or, you could get a tuner flash or chip to make the supercharger run correctly without any piggyback nonsense. Dynan did a hella good job with the software & tuning of my huffed m3. It is really an amazing setup.
Good luck; it should be great.
