Oil coming out of the MAF
I have read all the posts about oil in the intake but this is a bit much. The whole side of the air box is covered in oil from only 2 weeks of last looking under the hood. I had problems with a miss on acceleration and the Oil pressure light came on.
I was surprised to see I had lost 2 quarts of oil in 2 weeks since I had last checked it. I had only lost maybe a 1/4 Qt of oil between oil changes. I know the 525 does not have a pcv valve of any sort but what am I missing?
I have done the stomp test and I am getting a vaccuum leak code. I know a vaccuum leak can cause blow by but this is a bit much. I tried the Tbody cleaner and the Propane trick and got a slight rise in idle under the Intake manifold near the intake gasket. Could there be a leak at the tube going from the Block up to the Intake Manifold? or is that not under pressure?
Thanks in advance,
Jason
Boy is it ever on the volvo's.. : )
r
Quote:
Originally Posted by winfred
theres a hose that can crack under the intake on m20 cars, it goes from the throttle body to the valve cover that may be your leak, another sorce is the fuel system evap valve, it plugs into the bottm throttle body it can fall off. if you put your hand on the coil you most likely will get zapped even with good wires. i am not sure why it's puking oil as that's more of a volvo thing then a bimmer problem, that may be a sign of a problem
