1995 530i Vacuum leaks
Idle eratic. 1995 530i V8
Question:
Does the intake manifold have to be removed in order to replace the PCV plate / gasket on the rear?
Is there also a front pcv gasket on the V8 manifold?
If so does this necessitate removal of the intake manifold?
Is it just much easier to have the intake / pcv rear and front gaskets replaced all at the same time?
Thanks in advance for the info.
B.G.
I have heard that the rear plate can be removed without removing the manifold, but when I did mine, I just pulled the whole thing. The TORX bolts are a nightmare to get off, as the heads will strip and you have to VISE-GRIP them off. The front plate is just a plate, and also has a gasket.
Do a search for M60 Intake Manifold for a procedure. Bill R. and Winfred have pics of what it looks like pulled apart.
EDIT: Replace the four manifold gaskets as well.
good luck on the car! I did the 4 intake and the pcv plate and gasket and didnt do the front...I have to pull the intake again to do the front plate.
