Just have to know before I order the Coil-Overs that the rear top plates are the same in sedan as the touring.
Is the e34 525i Sedan REAR Top Plates the same as a e34 525i Touring??
Depends...are you replacing/deleting the SLS?
If so...then the rear shock mounts from any e34 will do.
SLS has already been deleted and changing out into Coil-Overs, however the compant I'm purchasing them from said the top mounts are different in a sedan than a touring.Quote:
Originally Posted by Blitzkrieg Bob
They probably dont know what they're talking about or they're talking about the SLS.
Quote:
Originally Posted by bad_manners_god
If so, then you already have the shock mounts from a none SLS e34.
Everything should work out.
