Anti-Theft Radio
I recently had to put in a new battery. The manuel states that I have three tries to put the code in for the radio. If that does not work I then must leave the igniton in the " 1" position for minimum of 1 hour, then try the code again.
I did all of this and the radio still reads CODE. What should I try next???:(
It means it still hasn't gotten the correct code. Do you have the radio code/code cards that came with the owner's manual stuff?
If not, pull the head unit, post the serial number (should be on a paper tag on the back of it), and I'll get you the code.
best, whit
