key won't rotate in ignition switch or start car
Neither of my keys will rotate in the ignition switch to start the car. Parked car, came back an hour later, and now neither of my two keys will work. So, it's not the keys, which are both intact.
What is the fix for a suddenly faulty or jammed ignition switch? The steering wheel will come unlocked (barely) with insertion of the key, so I've tried to start the car after turning the wheel either way, but no luck.
Can the ignition module be removed, and/or the car hotwired to drive home?
Advice, anyone?
ig. key won't turn in lock to start
When your ig. lock seized, was there any prior warning or indication?
Mine was totally symptom- and error-free until I went to start it after sitting for an hour. In other words, no history of being stiff, jamming, or whatever. I did not hear any noise from is as might be expected if an internal part snapped or broke, either. No nuthin--suddenly just won't turn more than just enough to release the steering lock, and then only when twisting the key. :(
It's a '90 535i automatic transmission
It easily turns about 45 degrees, but no further. It's been repeatedly doused with graphite locksmith's spray.
How does the shifter linkage come into play with this non-rotating key issue? The car will shift into Park, Neutral, Drive, etc.. I have the lower plastic cover off the ig. key/tumbler assy, but have not noticed any shifter linkage, just the multi-pin plug for the electric wires, etc..
Pls. advise, and thanks!
Quote:
if it turns part of the way I suspect its in the linkage for the shifter or clutch or something of that sort. no clue what car you have.
