how many liters will i need to do a brake fluid flush on an e34?
TIA.
Printable View
TIA.
The manual for my car says 11 US quarts. Yours may vary.Quote:
Originally Posted by shragon
11?!
hmmm, k, i'm gonna go look in the manual.
Sorry, That was coolant. I can't seem to find it in the manual. Maybe the Bentley, but that's at home.Quote:
hahaha yea, i just looked at the manual, and it's not stated in mine either.
my bentley is also at home.
case, don't break the seal on the second though until you need it, since its hygroscopic.
thanks bill! you always got the answers!!
it took the whole quart on mine cause I couldnt really tell where the dirty stuff ended and the fresh stuff started. I ended up having to get more to top it off.
i use 1 quart on back and follow up with one quart front, for whatever reason, my system gets dark within 2 years and i like not having to do things twice. it is probably overkill because my mom's previously unflushed ford taurus only took two quarts to do.
I used two 350ml bottles (Castrol LMA) to have my brakes flow clear using a pressure bleeder: That would have included the clutch too - until I blew air into it unwittingly: the clutch MC take off from the reservoir is near the top ?? - not the bottom!
Rob- do you know anywhere local to get some ATE super blue brake fluid?
It took me just over half a bottle of the ATE superblue do flush my brakes. weird. i exdpected it would take more, but no.
josh, www.xperformance.com in sj carries it. also edge motorworks in dublin has it.
i just looked at when my brakes were flushed two years ago, and only one liter was used.
Perfect. 10% off for bmwcca members. 15% of a case of redline fluids too. But, I wonder how thier pricing is. Thanks. :D
somebody called extreme up on bf.c, and it's $12 per liter for ate super blue.
