Hey guys - can anyone take a pic of their wheel hub w/ ABS toothed wheel?
I want to count the tooth number and such for traction control into my ECU
Printable View
There are two types and may have different # teeth. From Brunos site:
Up to 3/91 = 31-22-1-129-386 (left pic)
After 3/91 = 31-22-1-139-345 (right pic)
http://www.bmwe34.net/E34main/Mainte...a/Bearing2.jpg
http://www.bmwe34.net/E34main/Mainte...a/Bearing1.jpg
Dave
See I saw those two parts on Ebay Dave but I didnt know when the years crossed over! Thanks for that! I will magnify and count :)
Thank god - its an even number - I count 48 teeth on both wheels though, so, that makes that easy.
Dave in your vast wealth of knowledge, do you happen to know the individual gear ratios for a 1992 525i with 5 Speed ZF 310Z manual?
If its any help Jon, either will fit and work despite the difference in sensor/hub clearance.The later hub can have better SKF bearings fitted but they are not case -hardened so be carefull fitting them.
For ZF 310Z
1st 4.20
2nd 2.49
3rd 1.66
4th 1.24
5th 1.00
R is 3.89
