Option #226 - SPORTS SUSPENSION SETTINGS?
After discovering my E34 came with factory sports suspension (thanks to Ausmpower) I was wondering what exactly the package consists of?
Springs? Shocks? Sways etc?
My E34 doesn't appear obviously lowered but without comparing it to a car with stock suspension I can't be sure.
Springs, shocks and sway bars were different
Here's the difference in height using the different factory spring packages
Total toe is set the same as seen here on bmw
specs, the difference in toe at turn in are due to the difference in camber and caster due to the lower springs changing the camber and caster. The total toe in on the rear is different than the standard model also due to the camber changes.
Quote:
Originally Posted by Ausmpower
Most wheel aligners just set the sport suspension to the stock settings leaving you with an understeering dog at high speed.....
We get them in all the time on the e34/e39's. The Toe out is the key.
