Finally replaced the M60 valve cover gaskets...
I figured I would spend 2 or 3 hours with cleaning those magnesium alloy melting metal things, popping new plugs/boots a couple heli-coils and new gaskets and be done... After all I did this on Nikka and don't remember any issues so it should be straight forward. Pulled the coils and dove right in.
First off the right side (passenger side US) was a PITA to remove. Clearance issues with the AC being so close caused a removal angle issue until I removed everything all around, still didn't easily come off. Driver side was much easier.
Cleaning... off to the wife with lots of soap and hot water. That didn't work very well even though the water mixture was black. Next step was brushes and lacquer thinner and mineral spirits. Fluid again black as could be, like nobody even tried in advance. Clean, clean and clean again, never ending dissolving of the magnesium alloy. Almost spooky at times. If I had the funds I would have joyfully bought a pair off ebay that were already bead blasted and ready for primer/paint. Scraped the cosmoline paint stuff kinda smooth, almost enough to paint. Let this dry for a bit and take care of the other odds and ends I guess.
Anyway this is sucking tons of time so they are good enough for now. Soaked up the oil at the bottom the best I could with absorbent towels, this took another hour for both sides! (lots of oil) Pulled to old plugs without issue, to this moment have not studied them. Cleaned the plug wells a bit more, visually inspected the new plugs and installed without issue.
Back to these illusive covers... Heli-coiled the 4 top plastic cover threads that were completely gone. There are 3 or 4 coil pack studs that might be iffy but I failed to mark the questionable ones. Checked with spacers and the nuts and none seemed to be real bad on the right side. The left side had an issue and the stud seemed to pull out so I tried screwing it in deeper, no deal! Ended up pulling it out with a nut and the end of the threads had some sort of epoxy or JB weld on it. Someone thought they could glue it and stick it back in the hole... jeez man.
Time to quit, 7 hours now and the covers aren't even painted. Kinda raining and everything is soaked in dew or something. Cover it up and try again in the morning.
9 Attachment(s)
Lets do the "new" 540 M60 valve cover gaskets
Lets do the "New" 540 valve cover gaskets before I dive into the trans issue. I figure if I make everything good I am committed to this $600.00 car and trans issue. I will let the pics do the talking with comments. Magnesium valve covers are quite interesting. Apparently the "corrosion" keeps going kinda like a rotted tooth. Some say you can fix it with baking soda and water AFTER you remove the rot. I read into grinding magnesium and was looking into a major fire that couldn't be put out until I got to the kids wanting magnesium grindings to 'make' fire. Looked like I can grind the rot out with glasses and a respirator. Die grinder would be fine but I didn't have the right bits so I opted for the little one with variable speed (can't think of it right now). Edit: Dremel! Variable speed thing with round bits.
Attachment 8562
Attachment 8563
Attachment 8564
The above were before I messed with it
Attachment 8565
Attachment 8566
Attachment 8567
Attachment 8568
I guess this is how a totally nuked magnesium part becomes so messed up
I think one of the first things you do with a M60 is inspect the loose oil pump bolts and the valve covers. These leaked a little oil, enough to do the gaskets but not too major. Enough for me to practice on doing the job right. Glad I checked things out. Besides it looks good from the engine view. The hard (pass side US) has not been completed due to darkness, mosquitoes and that is the hard side to do but hopefully complete tomorrow.
This is one I picked up at the local pull a part. Looks like it was welded and was on fire but I think it is just magnesium corrosion Attachment 8569
Attachment 8570
