I left the window cracked open today and then it decided to start pouring cats and dogs outside.
Came out to find part of the seat closest to the window, seat back, door arm rest wet. Not soaking wet. Estimate the window was open maybe 20 min while raining.
Anyway, first the seat decided it needed to be all the way forward. Tried adjusting it, none of the power adjustments will work. The passenger mirror stopped doing its flip thing too when putting trans in reverse.
Checked Fuse 42? under the rear seat. Its a 30A fuse. Fuse is good. Reinserted fuse and the seat moved forward a little more.
Removed and replaced fuse again, now the seat moved all the way to the back.
Obviously, its getting power. Any suggestions to getting the adjusters to work? Remove and blow dry the switches? Is there a seat control module or something which should be dried out?
Any suggestions much appreciated. Its a bit of a stretch to fully depress the clutch now...
