Vfaq Micro filter replacement e34 (with pictures!!)
Needed Tools:
Good phillips and t20 screwdrivers,
also common sense as I may have forgotten a screw or two in this vfaq.
Please note that i shot these during REASSEMBLY so you may sometimes
see a part I already told you to move/remove. Pictures are a GUIDE
not the entire story, but aleast they'll give you an idea of what and where .
thanks to the e34 website for the original inspiration and sort of directions.
Step 1: remove glovebox. remove the straps from the glovebox
(lift up the narrow side of the metal retaining clip, push it off)
and undo the two latches under the glove box at the rear.
Step Two: Remove the carpeted trim panel by removing
the single phillips head screw
Step Three: remove the black plastic cover by
A: removing the black plastic clip that goes into the heater duct
and a phillips at the top &
B: pushing it backwards to disengage the retaining tabs .
http://i18.photobucket.com/albums/b1...r/100_0725.jpg
Step Four: Remove the Black floor vent tube,
There are two phillips behind the glovebox, one up top and maybe one other.
http://i18.photobucket.com/albums/b1...r/100_0724.jpg
Step Five: remove the grey plastic clip by squeezing the sides
and sliding it out
http://i18.photobucket.com/albums/b1...r/100_0723.jpg
Step Six: clip or slide down the ziptie that holds the wiring harness
that leads to the black box located aft of the microfilter.
This will give you enough slack to move that box aside
without disconnecting the plugs.
http://i18.photobucket.com/albums/b1...r/100_0721.jpg
