HELP: central lock non-function and ABS on
Hi,
it seems the central locking is not working from either locking from right door,
left door or boot.
I have hecked all fuses in the fuse box as well as fuses under the rear seat, all are fine.
What else i should diagnose?
Also my ABS light is "on" on the instrument cluster, what could be the cause?
regards,
If you elaborate a little bit more in the failure, ...
may be we can help. Not working is quite vague. You have 5 to 6 ways to operate the central locking, front doors knobs (and indoor handles), front doors keyholes, trunk lid keyhole, and keyless. Not all work the same way, knowing behavior for every operating alternative will help diagnose the fault.
Javier
Any other things not working? Wipers? Windows? ...
Roof? Interior lights?
Not working means nothing at all to me, Am I right?
Guess though that you can lock/unlock mechanically each door/trunk by key or manually. What about the gas filling port door? Any other issues?
Do you, at least, hear clicking relays at Relay Module, under the rear seat, besides General Module.
Javier
What about the windows, or are they manual? ..
Interior lights? I just can not found reasons for that general failure in the central locking having no issues at all in other GM related functions.
In this sentence, do you mean manually?
I can lock from the driver side,
Javier
