::.. 2000 RPM stutters...
Strange feeling now. Whenever the car is steady at the scenarios below, it stutters slightly as if you were nearing the stall point in a manual. Of course, it's not as strong a stutter... it's a fairly faint one but you notice it. The RPMs stay steady according to the dash gauge, but you feel it stutter under your foot ;)
2000 RPM - 2nd - 40 KPH
2000 RPM - 4th - 60 KPH (or was that 3rd...)
Anyway, it seems to only be at the 2000 RPM mark AND only when holding steady at that mark. If you give more gas or less, it 'goes away'. Maybe stutter isn't the best word. Let's try hesitations.
Haven't checked the other gears, but all I know is that it's not noticable in 1st... probably because of the gearing... can't feel it.
I notced the same on my 95 M50
Had the engine replaced with a used engine on my 95 525i automatic
(cracked block). Everything seems to run well except the same "hesitation" at 2000 RPM. The mechanice put in new plags with the engine, so I'll have to check to see what brand was used.
Any other ideas on what would cause this problem. If I accelerate or shift to sport mode, it goes away.
Mike Feeney
