Solutions abound, and a fix.
Quote:
Originally Posted by
632 Regal
The slip ring on mine gave me the greatest headache for a couple years. Not on Goldie (1994) that was in Michigan for 10 years came from georgia but the southern one (1995) from Georgia also. When cold the grease would freeze and bust the SRS (Orange) switch/connector. Search slip ring. I do not see as I can see any brushes going on in there. The only slip ring I can think called that is the little brass ring that was fitted where contact was made I ended up using graphite. Look up slip ring.
Nice work! Keep it up over there Frank87. May the rain clouds part wherever you travel!
* If I see a fault, I usually use some connector cleaner and then when dry, some conditioner on the contacts, not between. The ol' slip rings all need to have the new grease applied by now, as per 632 Regal's earlier posts on the subject
