I only have motor 1 and 3
I only have motor 1 and 3, then I have a cable controls where motor 2 should be.
http://i273.photobucket.com/albums/j...stepmotors.jpg
Can I pull the dash and open the top of the vent tubing and access the flap from there? Without having to pull the IHKA out?
http://i273.photobucket.com/albums/j...rventarrow.jpg
Quote:
Originally Posted by
shogun
These are the exterior air vents
Yes there is a motor on the drivers side (USA) and a cable that actuates the fresh air vent on the passenger side but this is fresh air vents that are on the firewall. The vents that I am talking about are in the interior of the car. Looking at all of the pictures it appears that if the dash is removed you should be able to remove the top of the IHKA without removing it. But then again I may be talking about the duct work on top of the IHKA. I think if the duct work is removed I should be able to get a closer look at the flap and perhaps repair it. What do I have to loose I still have to remove the dash anyway :) Now its off to find instruction on dash removal.
shogun
