Is it for power adjusting steering column? I'm referring to the one not highlighted by the sun.
http://images8.ecarlist.com/photos/1...588/640/48.jpg
Printable View
Yes.
Yes and it doesn't belong in an '89.
believe this photo is of a 95 because the steering wheel has an acutal rondel vs stamped in the airbag cover.
That would make sense. I was assuming it was the car belonging to the poster.
Is modding this steering column into a non electric column possible ?
May be possible. However, you may need to avoid a car made after 1/95 as it has a more advanced security system/lock which may not be compatible with an older car.
its a 95 value pack car or an early car with a column swap
All '95s have telescoping columns, but early non-540 '95s have manual telescope, all later '95 cars (I think 1/95 was the changeover) have power telescope. Might be easier to just swap the power column with a manual one because of the way the mechanisms work. EWS shouldn't be a problem, regardless, because the antenna ring fits around the ignition cylinder...standardized.
edit: sorry russell, that wasn't necessarily directed at you, just hit "respond"
