7 Attachment(s)
Replacing the hose connecting VolumeAirFlow to Throttle plate (pics and tips)
Hello together,
I noticed a few days that the hose which connects the Volume Air Flow Meter to the throttle body was damaged at the point where the PCV-pipe adapts. Here is a pic:
Attachment 8406
I was suspecting that the engine was sucking atmospheric air through the damaged rubber hose, so I replaced it. In case you also have to replace it, here is the procedure. It is pretty easy actually. You need the new hose (P/N 13541722847) and two clamps:
Attachment 8407
Start by removing the air filter housing, and then you must also remove the air flow sensor. It is held down on the valve cover by three 10mm nuts and two of them are directly under the sensor so it is a bit tricky to reach them. When you get it out, it looks like this:
Attachment 8408
Then you have to unplug the PCV-pipe and the Idle Control Unit from the rubber hose and take it off the throttle body. Check the PCV for deposits. Suprisingly, mine was pretty clean in the inside. The area around it need cleaning however. It is also a good time to check the inside of the throttle body, by opening the butterfly valve.
Plug the PCV and the IdleControl on the new rubber hose and at the same time slide it on the throttle body opening.
Attachment 8411
Then connect the air flow sensor on the hose and bolt it down on the valve cover again. Also connect the air filter housing again.
Finished
Attachment 8412
