PROCEDURE: Fixing broken bolts on the fuel tank where the fuel sending unit attaches:
Section 1 of 4:
Quick Summary:
http://www.captive1.com/mrk/1_normal_broken_w.jpg
http://www.captive1.com/mrk/2_bolt_repair_diagram_w.jpg
A: Drill a small pilot hole as straight up and down as possible.
B: Drill a larger hole, the necessary size for the new bolt.
C: Thread the hole from the bottom up.
D: Install the new bolt with rubber washers
Detailed Explanation:
The Problem: You need to remove the sending unit from your fuel tank and you break a bolt while trying to get it off.
In my case, I soaked all eight bolts with penetrating liquid for five days before I tried to loosen them. Six came loose, but two broke loose from the tank at the rivet/weld underneath. The nut and bolt just spun when I turned it. So to get my sending unit off, I needed to break the bolts intentionally…and then repair them afterward.
http://www.captive1.com/mrk/3_rusty_closeup_w.jpg
I had two bolts that needed to be fixed. Note the rivet/weld underneath:
http://www.captive1.com/mrk/4_two_broke_one_good_w.jpg
