i think i know what size but better ask. Im going to convert to 16s for the summer treads.
Thanks!
Printable View
Thanks!
can you go and measure my tires circumfrence for me? Its cold out there.
Check Tirerack's page & pick your favorite tire and then click on "Spec's", it will give you tire diameters for all sizes. Stock for my e32 is 225-60-15 which is about 25.6" to 25.7" o.d. depending on brand. I've been running 16" tires for a year or so & they make a great compremise for comfort and handling. My next set of tires are going to be staggered with 245-50-16 in the rear & 235-50-16 in the front if they clear, otherwise 225-55-16 in the front. I prefer to go with no more than a 50 profile, 55's are a bit mushy for a summer tire.
Then again, if you go to a minus 1 like a 225-50-16, it effectively tweaks the final drive ratio and will give a bit better lowend performance & the smaller tire offers better turn-in.
just punch in 225/60/15 and use that for the refrence size
Quote:
225/55/16 seems as close as you can get based on a bone stock size of 205/65/15.
Although if your wheels are wide enough(say...16x8), I think a 235/50/16 would be a great choice.
I've used this java page for as long as I can remember to calculate correct tire profiles: http://www.miata.net/garage/tirecalc.html
