License Plate Light error
Quote:
Originally Posted by Gayle
Maybe I am saying something stupid, but thats my job here. If I understand your post, you are saying that you are getting the license plate light error message but the license plate light is actually ok. I thought when this happened it was usually a failed sensor.
The driver's side light works, the passenger side does not. To make a quick
fix, I wired the 12 volts from the driver's side to the 12 volts of the passenger
side. The problem is, I still get the error message. So the wire for the 12 volts
must be open. To fix it, I somehow need to replace the wire in the harnass,
but that would be a nightmare. I don't know where the wire comes from.
That's the problem. I need a wiring diagram.
