i need to find the location of the relay and fuse that covers my service lights on the instrument panel as they have suddenly stopped working they dont even light up when ignition is on
Printable View
the lower line of the check control is not controlled by the light dimmer but by a photocell, that is where the 3 ??? are
http://8810.teacup.com/750hiline/img/bbs/0000689.jpg
Maybe you just change the bulbs as a first step.
ok thanks i will look at the panel and see if it has bulbs thought it was an lcd type panel ?
no bulbs in the display
there are bulbs behind the display! Not in the display.
Go to my website and read
Removing the airbag and changing the dash bulbs
the clocks on my 1995 are different to those on your link
also it was posible to remove my clocks without removing the steering wheel
ajusted steering colomn and slid past the indicator stalk side
