Oil still leaking after Oil Pan and Oil Filter housing gasket replacement
I replaced the Oil Pan Gasket and the Oil Filter housing Gasket a month ago on my 95-M50 and I still have a small but annoying oil leak. I checked all around the oil pan and it seems fine with no obvious leaks and so is the oil filter housing.
The oil seems to be accumulating and leaking from the levelling switch one drop at a time #10 here...
http://www.realoem.com/bmw/showparts...98&hg=11&fg=10
I didn't change the levelling switch ORing (#12) at that time. I remember jacking up the engine (with mounts off) to get the oil pump out. So in order to just replace this ORing, do I have to lift the engine again?
