Need help with window regulator
Good morning, hope you all had a great weekend!
I installed driver side rear window regulator over the weekend and I am having a problem. With the limit stop mechanism installed I can not get the window to travel to the fully closed position (IOW- all the way up). Before I rip the regulator back out, I am just wondering if the square shaped socket on the window motor is a fine adjustment screw? Sorry for the lame description, but I do not know what to call it -- I wish I had a digital camera...
TIA
No, it is not, its the bearing point for the worm drive from the
motor, do not adjust it... The stop is as pictured on the front window, the rear is similar, you can adjust it therehttp://www.bimmernut.com/%7Ebillr/images/windowstop.jpg
TIA
