http://www.123usedcars.com/car-recalls/01-123/bmw/
Printable View
Thanks Erich - another great mine of information. :)
keeps saying "There is currently no recall data available for this 1994 BMW 5-Series 540I" .... or other such car....
Looks like not all are working. For my car it works
NHTSA Recall ID Number: 90V016000
1989 BMW 7-Series 750IL Recall Date:
01/30/1990
1989 BMW 7-Series 750IL Component:
SEAT BELTS:FRONT:BUCKLE ASSEMBLY
Potential Units Affected:
13100
Summary:
UNDER CERTAIN CONDITIONS, FRONT SEAT CENTER, FOLD-DOWN ARM REST MAY CONTACT THE SAFETY BELT BUCKLE, CAUSING DAMAGE TO THE RELEASE BUTTON AND PREVENTING THE BELT TONGUE FROM LATCHING WHEN BUCKLING UP.
Consequence:
OCCUPANT WOULD NOT BE PROPERLY RESTRAINED AND COULD BE INJURED IN THE EVENT OF A SUDDEN STOP OR ACCIDENT.
Remedy:
REPLACE FRONT SEAT SAFETY BELT BUCKLES WITH SHORTER VERSION THAT WILL NOT CONTACT THE ARMRESTS. NOTE: OWNER NOTIFICATION DATE; 2/90 IS PREPARED IN DRAFT FORM.
Notes: BAYERISCHE MOTOREN WERKE,
NHTSA Recall ID Number: 89V005000
01/17/1989
VEHICLE SPEED CONTROL:ACCELERATOR PEDAL
13100
Summary:
ACCELERATOR PEDALS MAY NOT HAVE BEEN PROPERLY ATTACHED TO THE FLOOR PAN DURING ASSEMBLY.
Consequence:
UNDER CERTAIN CONDITIONS, PEDAL MAY BECOME STUCK AND NOTFULLY RETURN TO THE IDLE POSITION WHEN THE DRIVER REMOVES HIS FOOT FROM THEPEDAL CAUSING LOSS OF CONTROL, WHICH COULD RESULT IN AN ACCIDENT.
Remedy:
COMPLETELY SEAT LUGS IN THE RECESSES OF THE FLOOR PAN TO ASSURE PROPER ATTACHMENT OF THE GAS PEDAL.
that means that they never recalled a 540 produced that year.Quote:
Originally Posted by swenpro
There definitely should be recalls, my whole engine has been replaced under warranty, and I just replaced a throttle cable that sawed its way through the hose--I think that was a recall item as wellQuote:
Originally Posted by Espen
Ha! Checked mine. Throttle cable issue that could cause throttle not to close completely. Consequence Vehicle may not "decelerate as expected"
Masters of understatement I'd say.
Yep, works for mine. My local dealer told me there was a recall outstanding on mine and they would fix it for free! It was just a check to see if anyone changed the rad cap since 1992 :-)
