Originally Posted by joshua43214
Verify you have no injector pulse as well as no spark. If you are missing both, then look for problems that relate to both fuel and spark, such as bad CPS. If you dont have a noid light or high impedance ohmeter, you can often just listen to, or place a finger on the injector while an assistant cranks to see if it is clicking.
No starts pretty much all start the same way, check for both spark and fuel, it makes a difference in diagnosis if you have no spark, no fuel, or neither. Cover all the basics first before moving to exotic things. Check ALL the fuses with a test light on the back of the fuse, make sure you have power to the coil and injectors etc.
let us know what you find.
