Microfilter or Cabin filter?
Hi y'all. My A/C just is not blowing like it should (air pressure out of vents) I just went to the BMA page and they list two filters for my 92 535. Both listed as "fresh air filters" the first is called the CABIN FILTER and the Second is the MICROFILTER. Do I need both? Does my car have both? Any help or tips on this will be very appreciated. :)
You still don't have the clasps adjusted correctly if it
closes like that. The clasps slide back and forth in the slot before you tighten them down. Close the glove box, then underneath the glove box unfasten the clasps. with the clasps loose, move the box around until the pieces up front line up correctly then latch the clasps to lock it in place.
Quote:
Originally Posted by Jehu
email BMA from their contact us form. They will respond. I bought mine from the local Dealership $35.00 but i didn't have to wait for it to arrive. I had the thing out when i went there and installed it in their lot. Only thing is my glove box now seems to close a half inch lower than before .It closes tight but isn't flush with the wood trim strip .I lay down looking up at the back and i can't seem to see any other way of fitting those clasps on the rail than it is now.
