I've got the Sachs kit and I'd like her to be another 0.75" lower all around. Is there any easy way to achieve that? Will it mess up my suspension geometry/handling?
Printable View
Bags of sand in the rear footwell.
I agree, sandbags.
Do you have the 3mm front spring pads? Stock is 9 so you can get a 6mm drop. No clue on the rear
let down your tyres. that should lower it that bit more....
lowering will affect your geometry, particularly increasing camber in the rear. this can lead to premature tyre wear.Attachment 2889
How much are you lowered?Quote:
Originally Posted by stx133
My fronts wear more on the inside than my rears right now. hehehehe.
3mm pad in the front..and if you want lower in the rear...put it on the lower of the two settings?
how low can you go....
Quote:
Originally Posted by Nick.Hay
if it was a poll, this would get my vote:p
13.00 @ 100mph in the Can-Am with a 462 pump gas street tires
9.97 @ 135mph in the dead Regal with the small motor
8.58 @ 158mph (est.) with the 632 project
