My speedo stopping working?
This morning when I left for work I noticed my speedo indicator was not working.
Correspondingly the odometer and the ODB's KM's remaining were also stuck in a time warp. After I'd travelled about 5kms everything came back to life.
It was fairly cool this morning around 5 celcius. I'm figuring either something temperature related or a loose connection between the speed sensor and DME.
Did the chime go bong the first time you hit the
brake pedal after starting the car that morning? If so then it is probably the capacitors as others have suggested, I would check the connection at the speedo sensor back at the diff, if it was that cold then its possible that it was a bad connection.
