Originally Posted by
Tiger
I had this problem long ago when I first installed HID... 2001. I would get this problem and the light actaully does not lit. I pulled out the LKM many times and finally solved the problem without realizing it.
Reflowing and adding solder is so damn easy... 1 minute job.
Open up the cover of LKM and stick it back in the socket... you can manually activate each relay to figure out which one is low beam relay.
Other thing I did is scrape the relay contacts clean... this cinch the job... because the contact oxidation creates resistance... causing the error message to trigger... all that arcing when relay closes.
