can the e34 CV joint be relubed WITHOUT removing the whole shaft....
more specifically, bentley says that the joint must be pressed in and out. is this something that could be accomplished with the other joint remaining on the car, ie, by hand or with a puller? i'd rather not have to crack all of those 75 lb ft hex bolts just to take the boot off.
Ryan, what you describe is not the cv joint, its the differential, put some
redline synthetic in it and it will quiet right down.
Quote:
Originally Posted by ryan roopnarine
Today 01:13 AM
winfred it's generally good practice to leave em alone unless the boot is torn, it's just not a part that normally wears out on bimmers, yes it's a pain to replace the boots i get good practice on 850 volvos, they suck ass and split all of the time
the only reason i'm contemplating doing the boot is because the cv joint has begun to moan at certain speeds, and i'd rather not wait for it to die (if it is indeed) lack of lube that's making it sing. thought it was a wheel bearing at first, but it only occurs when the gas is applieed, and it doesn't make the noise in coast. the boot is in remarkably solid shape, though. i have to do brakes next weekend, i might just slide the boot forward, see if the grease is dust-ified or not, and if it is, clean it out and shoot some new stuff in there. do you have any idea as to how long i likely have left with the joint in such a condition?
Its not worn out fluid, its wear on the pinion and lash in the gears causing the
noise and it usually only does it in straight line. Usually more noticable at 50 mph and above, typically the faster you go the louder the noise is as the diff wears. And by giving it gas the noise is there, but when you back off and coast just right the noise will go away. I don't know why you would hear the groaning only on one side of the car.. I wouldn't really describe the diff noise as a groan its more of a whine to me.
moaning......differential.......
i thought it might be the differential, but the problem is is that its only groaning on one side of the car, and its not doing it when turning (only in straight lines). is the diff compartmentalized sufficiently to have worn out fluid cause a noise on only one of the two wheels?
