Originally Posted by
paanta
FPR is brand new Sorensen (a brand that seems well trusted among the Volvo + Saab folks). I replaced the old one because of a slight gassy smell in the vacuum line, but it didn't change anything.
36 PSI at idle up to 44 PSI at tip in, then back down to 36 psi once it stabilizes at a higher engine speed. It seems low, but the FPR does limit it to precisely 3 bar with the fuel pump relay jumped and the car off, rising to 4.5 with the return line pinched, which is what the Bentley spec says. So I think the FPR is ok.
If the FPR were bad, I'd expect it to run poorly more consistently, not just for a few seconds after startup. Even running poorly at idle, it has a distinctly electrical problem-esque thing going on...if you can get the engine over about 2500 rpm, it'll clear its throat and suddenly run fine until the engine speed drops back down to near idle. And yes, I've tested the throttle position sensor. And the alternator+battery.
I could start throwing parts at the problem, but I've been there, done that. No desire to blow through $500 trying to track what's hopefully a simple issue.
I keep coming back to thinking it might be a problem with the ECU itself or maybe a bad coil, though neither one can be tested real easily. Maybe the AFM pot is dirty? That's one thing I haven't tested yet. Weird values could throw the mixture off and give me that error 1222 I suppose. I'll check that tonight...
