How to replace oil pan gasket? plz help!!!
Its for 1990 535I with an M30 3.5l engine
I need to replace my oil pan gasket, i went to the mechanic shop the guy said he cant do it, u have to lift all the engine up or take the whole front out lol, because the oil pump is in the oil pan. Is that true?. I can do the job my self but im not sure if u have to do all these things. Can i do it in my garage or i need a car lift? And the bolts on drivers side are pretty hard to get too.
What is your mechanical aptitude?
your mechanic is correct about the difficulty of getting at the oil pan b/c of the shape and oil pump being in the way.
If you are at all skeptical about your own abilities, I would leave this up to a mechanic....at least until you build up ability/experience/knowledge.
You have to get the car up on stands....
Then you have to jack or cherry pick the engine up enough to clear the subframe crossmembers in order to pull the pan out the front. Most of the time you need to remove the pump pickup while the pan is half hanging off so that you can drop it out of the way and then pull it all out together.
Thas is the general idea.
How difficult is it what do you have to do? and remove?
You want the Beck Arnley gasket
You can get it thru NAPA. Waaaaay better than the stock cork gasket.
Quote:
Originally Posted by Martin in Bellevue
Small hands would help when dropping that pickup while the pan is in the way. The motor doesn't have to go up too high, loosen the coolant reservoir & pull away from the firewall for an idea of the clearance needed.
Also, avoid the damn cork gasket. Napa has a better gasket available, although, I guess the cork gasket on my 535 lasted 15 years before a corner gave.
