I am refinishing my rondells. They are being VERY stubborn as far as stripping them goes. Has anyone ever stripped wheels? Recommend me a GOOD (proven) stripper!
Printable View
I hear that 'aircraft stripper' available at autobody supply shops is the stuff. Couldn't say if it works on wheels or not. If they are powdercoated, I might guess not. If painted, likely it will work. Might ask at the supply shop.
Aircraft stripper blows. Everyone recommends it, yet 9/10 times people have never tried it for what they are recommending it for. Jon, I have used this really expensive, really toxic stripper for wheels before. It'll cut through anything without damaging the metal, but it isnt cheap at $40+ per gallon. If you want me to find out what it is I can. A large rubber bin with this stuff diluted with water, let each wheel soak for an hour or so, then spray with a pressure washer (or wipe the paint off with a rag, but I prefer clean surfaces). Then of course you need to dry, clean, and sand out any imperfections in the wheels, etc, etc.
Oh and DO NOT get it on your skin, of course ;)
Jon, When i redid a set of style 5's about a year ago I stubled upon Peel Away 3 at Home depot. I had bought this stuff to strip the paint off of my kitchen cabinets and had some left, so i tried it on the wheels. Amazing stuff. You spread it over the wheels and let it sit for like 6 hours, then you can wipe all the paint right off, the paint actually peels right off, without damaging the aluminum(i polished the lips). You can even use it indoors, it does not give off fumes and says it safe for indoor use. Its a little pricey, like $14/qt, but well worth it
Did anyone try it on Chromed wheels? I am getting a set of rare MB wheels that has peeling chrome.
I don't know what is under my wheels - maybe its an etching primer or somethig, I am not sure.
http://blowneuroz.com/mygallery/Refinishing/close2.jpg
see the white **** under there?
the white **** is probably epoxy primer, most of my paint stripping projects involve some sort of spray stripper like aircraft stripper or bulldog, but i can't remember trying it on wheels, the only thing that AS hasn't done for me is touch that crusty **** under the paint on dohc bmw valve covers, that ****'s insidious
You can not use any paint stripper on chrome. Chrome is chemically bonded onto the metal.Quote:
Originally Posted by Tiger
You have to take it to a chrome place that will dechrome it. It can take up to 2 weeks to dechrome since they put it into a chemical acid that is diluted so it won't damage the actual wheel itself.
I've got the same primer on my style 32s, just been taking a dremel sander to them after stripping as much as I could off with sanding + aircraft stripper.
