Threads 1 to 28 of 28
Forum: Suspension & Steering
PM Archive suggestions to: billb
  1. Removing the Thrust Arm Ball Joint
    Started by Adnan, 08-18-2004 07:28 PM
    02-04-2021, 09:03 PM Go to last post
  2. Bump Stops for lowered cars
    Started by 632 Regal, 08-21-2010 05:38 PM
    bump, bump stops, bumpstops, stops
    08-21-2010, 05:38 PM Go to last post
  3. Sway bar options
    Started by Anton CH., 09-02-2005 01:22 PM
    09-02-2005, 06:30 PM Go to last post
  4. What steering components commonly fail?
    Started by Jay 535i, 09-01-2005 09:47 PM
    09-02-2005, 05:35 PM Go to last post
    09-02-2005, 11:36 AM Go to last post
  5. Steering
    Started by Exnilo, 08-31-2005 09:19 AM
    08-31-2005, 05:43 PM Go to last post
  6. Jammed shock rod nut
    Started by ElNormo, 08-30-2005 05:18 PM
    08-30-2005, 06:35 PM Go to last post
  7. Stock ride height
    Started by Alexlind123, 08-28-2005 03:08 PM
    08-29-2005, 01:01 AM Go to last post
  8. Front collar nut size?
    Started by Anton CH., 08-28-2005 02:15 PM
    08-28-2005, 06:51 PM Go to last post
  9. Front eng thunk when going over small bumps
    Started by pshirley, 04-05-2005 10:09 PM
    04-08-2005, 05:54 AM Go to last post
  10. Maximum Offset? 90 535i? ET30 okay? or No?
    Started by Guelphguy, 04-04-2005 07:54 PM
    04-05-2005, 11:51 PM Go to last post
  11. Help needed - I broke the subframe bolt
    Started by BigKriss, 03-21-2005 08:19 PM
    03-31-2005, 12:15 PM Go to last post
  12. New Suspension Needed......
    Started by western99, 03-17-2005 07:59 PM
    03-18-2005, 12:02 AM Go to last post
  13. the car is pulling a little right
    Started by paschalisg, 03-12-2005 12:16 PM
    03-13-2005, 07:29 AM Go to last post
  14. Strut Clunk!!
    Started by prasad, 03-08-2005 01:08 PM
    03-12-2005, 04:11 PM Go to last post
  15. Thrust arms bushing Inserts
    Started by Bruno, 02-15-2005 03:40 PM
    03-01-2005, 05:25 PM Go to last post
    02-19-2005, 08:40 PM Go to last post
  16. Hey winfred! Steering wheel exchange question.
    Started by Warren N.CA, 07-12-2004 05:02 PM
    07-13-2004, 10:44 AM Go to last post
  17. Online ETK
    Started by G Feller, 07-01-2004 01:01 PM
    07-01-2004, 01:01 PM Go to last post
  18. Need Help with Shimmy Diagnosis (Long)
    Started by talltorontoguy, 04-26-2004 09:20 AM
    04-26-2004, 11:06 PM Go to last post
  19. stumped on 50-60mph shimmy
    Started by jplacson, 04-03-2004 10:07 PM
    04-20-2004, 12:11 PM Go to last post
  20. 40-60 MPH shimmy
    Started by Jazzman, 04-13-2004 01:08 PM
    04-17-2004, 04:15 PM Go to last post
  21. Thrust arm replacement question
    Started by ilya, 04-03-2004 02:36 AM
    04-10-2004, 09:16 PM Go to last post
  22. What's up with my steering?
    Started by Dan in NZ, 03-15-2004 02:47 AM
    03-15-2004, 08:26 AM Go to last post
  23. Thrust Arm Bushings
    Started by Riddler, 02-15-2004 01:31 AM
    02-15-2004, 02:23 AM Go to last post
  24. Rear shock removal woes.....
    Started by Dave M, 02-12-2004 10:31 AM
    02-12-2004, 06:21 PM Go to last post
  25. Bilstein Sport Install Questions
    Started by JR'Z 525, 02-10-2004 10:26 PM
    02-11-2004, 08:45 PM Go to last post
  26. Will this M\\Tech Wheel fit my 90 535i????
    Started by Deke NorCal, 02-02-2004 09:04 PM
    02-03-2004, 04:46 PM Go to last post
Forum Information and Options
Moderators of this Forum
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
