Threads 1 to 30 of 40
Forum: Engine & Drivetrain
PM suggestions to be archived to: dacoyote
    04-25-2020, 09:24 AM Go to last post
  1. M30 (535i) crank nut size
    Started by rickm, 06-30-2004 01:52 PM
    01-27-2014, 07:45 AM Go to last post
    03-11-2009, 12:56 AM Go to last post
  2. raditor cap
    Started by bmwrp8, 01-03-2009 06:41 AM
    01-03-2009, 10:18 PM Go to last post
    12-26-2008, 10:36 AM Go to last post
  3. M30 cam profiles - one for the archives
    Started by Jeff N., 03-22-2008 11:20 AM
    03-22-2008, 11:20 AM Go to last post
    12-16-2007, 01:19 AM Go to last post
  4. ZF tranny oil reference guide
    Started by shogun, 09-30-2007 11:38 PM
    10-01-2007, 12:12 AM Go to last post
  5. Looking for Answers Definitive ATF fluids post
    Started by Bill R., 03-22-2007 11:55 AM
    2 Pages
    1 2
    03-24-2007, 11:22 PM Go to last post
  6. special BMW repair tools
    Started by shogun, 02-21-2007 09:04 PM
    02-21-2007, 09:21 PM Go to last post
  7. How much should a clutch job cost on a 540?
    Started by bbig119, 10-09-2006 05:19 PM
    2 Pages
    1 2
    10-20-2006, 10:55 AM Go to last post
  8. M60 Check Engine - Problem / Solution
    Started by FWinNH, 03-03-2006 09:35 AM
    03-03-2006, 09:35 AM Go to last post
  9. Starter motor makes strange noise, then smoke
    Started by EdNL, 01-03-2006 05:13 PM
    2 Pages
    1 2
    01-05-2006, 01:36 PM Go to last post
  10. Fuel pump/starting problem for the electricians and experts
    Started by azale, 09-27-2005 08:58 AM
    7 Pages
    1 2 3 ... 7
    10-11-2005, 09:55 AM Go to last post
  11. M30 oil pan removal...calling Hector and George M
    Started by Robert K, 07-18-2004 09:32 PM
    07-20-2004, 09:37 AM Go to last post
  12. E28 Wont Start - No Spark
    Started by Jimmy535i, 06-21-2004 08:22 AM
    2 Pages
    1 2
    07-12-2004, 08:19 AM Go to last post
  13. valve adjustment tool?
    Started by panzershreck, 07-11-2004 06:57 PM
    07-11-2004, 08:08 PM Go to last post
  14. Oxygen sensor substitutes - Revisited
    Started by happifella, 07-04-2004 12:03 AM
    07-06-2004, 10:49 AM Go to last post
  15. 95 540i - puff of smoke on start up
    Started by Rick, 07-04-2004 05:46 PM
    07-05-2004, 02:55 PM Go to last post
  16. Banjo bolt backed itself out, front end ticks now... how bad is that??
    Started by TC535i, 07-01-2004 11:35 PM
    2 Pages
    1 2
    07-02-2004, 11:29 AM Go to last post
  17. Intake manifold removal.....
    Started by Dave M, 06-30-2004 02:50 PM
    07-01-2004, 07:38 AM Go to last post
  18. Engine Code website
    Started by Daskoff, 06-30-2004 01:43 PM
    07-01-2004, 12:11 AM Go to last post
  19. 0W-30, 0W-40, 15W-50......I'm lost
    Started by BennyM, 05-04-2004 05:39 PM
    5 Pages
    1 2 3 ... 5
    05-07-2004, 12:03 PM Go to last post
  20. Valve adjustment tricks--535i variety
    Started by Bart, 04-26-2004 12:03 AM
    04-26-2004, 01:50 PM Go to last post
  21. Just gotta ASK , WHAT THE HECK IS A VANOS?
    Started by Drooby, 04-20-2004 03:08 PM
    04-20-2004, 09:18 PM Go to last post
  22. Possible Headgasket problem; need help!
    Started by Al Gray, 04-03-2004 05:43 PM
    2 Pages
    1 2
    04-03-2004, 11:50 PM Go to last post
    04-02-2004, 09:42 PM Go to last post
  23. Clutch Job, and advice
    Started by Bimmer Nut Ed, 03-07-2004 01:33 PM
    03-07-2004, 01:36 PM Go to last post
  24. Shift Linkage Rebuild DIY - LARGE
    Started by Dave M, 02-23-2004 01:56 AM
    2 Pages
    1 2
    03-01-2004, 03:31 PM Go to last post
  25. 540i/a running rough continue's
    Started by tim s, 02-25-2004 06:19 PM
    2 Pages
    1 2
    02-27-2004, 09:22 AM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
